Rheem vs Carrier
1 reading
9.6K views 13 replies 6 participants last post by  NWCherokee
#1 ·
So comparing two quotes. Both HVAC contractors are well regarded 30 plus year companies. In fact, I have worked very successfully with both companies on commercial projects in the past as they both have in-house design ability. These are coming in within $500 of each other with the 96% Carrier being the more expensive:
Carrier 96% Performance two-stage 59tp6b060v17-14
Carrier Performance 16 SEER single stage 3-ton 24acc636a003
or
Rheem 80% 2 stage variable speed R802va075317zsb
Rheem 16 SEER 3-ton RA1636AJ1NB
Was curious if anyone had any thoughts on this particular Carrier or Rheem equipment and 80% vs 96% in the Portland, OR area? I am currently leaning toward the Carrier, but I am open-minded.
#2 ·
You ain't comparing apples to apples. Why get a quote on a 80% from one dealer and 96% from another? What do most do in the area for heat? Seems to me it's a fairly mild climate so maybe 96% isn't justified. Might ask the Rheem dealer why he's quoting only 80%. Only other comment, the 24ACC6 is a more deluxe unit than the RA16. Sound blanket, compressor protection, American made as is the furnace. The furnace appears to have a constant torque motor even though Carrier uses the term variable. The Rheem is fully variable. It's also communicating with the Econet control (Rheem's version of the Carrier Infinity).
I read you are having a heat wave, stay cool!
#3 ·
only other comment, the 24ACC6 is a more deluxe unit than the RA16. Sound blanket, compressor protection.
Maybe Rheem/Ruud is "finally" getting the message, we are actually getting the latest RA16's with pressure switches, miracles never seize. :eek2:
Save
#4 ·
I agree, those quotes are completely different.
I would want to know why the contractor chose the systems hey did for the quote.
But if the companies are solid, and both will properly install and balance the equipment, I would choose Rheem over carrier.
16% more efficient furnace, but condensing has some placement considerations to deal with.
#6 · (Edited)
According to this specifications sheet your model number Rheem says it has a High and Low pressure switch.
https://s3.amazonaws.com/WebPartners/ProductDocuments/BC54CD66-87D1-46DA-B247-95CB3ED28330.pdf
Page 3 SKU.
If you want to know the SEER and EER ratings of both models would need the complete model number and brand of indoor coil to you, you can’t go by the rating of the outdoor unit solely.
Also the 96% furnace should apply for local rebates along with the A/C if you can prove it meets the minimum threshold for rebates, reason for asking for the AHRI number. Did you ask them for that number to prove efficiency ratings? If not ask them..
There is also the Federal Tax Credit for high efficiency systems.
Did they mention possible rebates and the Federal Tax Credits to you?
https://www.energystar.gov/about/federal_tax_credits/non_business_energy_property_tax_credits
Possible rebates https://www.google.com/url?sa=t&rct...BlgQFjAAegQIBhAD&url=https://www.dsireusa.org/&usg=AOvVaw19WUxQBTiQc0GVu13UMfK_
Make sure to register your system of choice as manufacturers warranty decreases if never registered.
What’s the labor warranty of each Contractor, is one offering more than the basic one year, if so is that a plus consideration for that brand?
If one model has a slightly higher SEER and EER ( once finding out the AHRI number ) is that a consideration also. Granted those SEER and EER ratings are not real world but certainly applies for rebates.
What if one model gives you 15.5 SEER and fails to qualify for money in your pocket rebates and the Tax Credit while the other gives you 16 SEER and qualifies for rebates and Tax Credits, is that another consideration to lean toward that model brand?
Save
#9 ·
I don't think ps are standard. The distributor has to order them that way. If so, the model # ends in B. Our distributor only orders the A versions without switches. Mr Bill's distributor may have gotten wise and started ordering them that way.
#10 ·
Thank you for letting me know about the B version, my guess is this "right now" is a real hush, hush, until they get rid of all the older versions, because the counter guy didn't say a word about any model number change, and I never really look past the RA16 except for tonnage on the model number.
Save
#14 ·
So I thought I would post what I actually got installed, which ended up being something else... One of the issues I had was that my existing AC unit was located too near my rear garage man door. Well, not too near for the existing AC which was quite narrow, but all of the proposed units would have blocked the door enough to prevent me from getting full use of the pathway. The only other location I have that would work was the opposite side of my house. This increased cost a bunch to relocate the electrical, remove very mature shrubbery and build a screen wall for the HOA since I am on a corner and it would show.
Instead, I decided to go with the Daikin Fit which would shoehorn perfectly in the area due to its narrow width. So I ended up with a Daikin DC96VC0603B 96+ furnace, Daikin Fit DX17VSS36 outdoor unit and, CAPEA3026B coils. The best part is that the fit is now on the other side of my family room wall and I can't hear a thing. The old 10 seer Payne AC was screamin' loud due to being a cheap 23 year old builder spec model. So far very happy....
