I found a contractor that will install the unit I am looking at but he said 2 things that I have questions about.
-First he said with a 2-stage communicating A/C unit (In this case Goodman GSXC16 w/ComfortNet) that I have to use the goodman thermostat. I believe that the unit can still be wired traditionally into my Honeywell HZ322 (2H/2C) controlled by 3 seperate single stage thermostats. Is this correct? From my understanding ComfortNet does not support zoning.
-Second, he said that even though the coil case is 24.5" and the furnace is 24.5" that they would be "incompatible" and that I would have to change the furnace out as well to go with the 2-stage condenser. Is this accurate?
Thanks Again!
Thanks Again!
