I am my wit's end on this one, fellas. Unit fires up as normal, but gas valve shuts off after 1-2 seconds, exactly as if the flame isn't sensed.
I'm the second guy in there, which of course we all hate. Homeowner says the other guy diagnosed it as a bad board but he couldn't afford it then, so wanted me to replace it. I could tell the other guy even tried a new flame sensor and for some reason, the flame sensor wire is spliced to the harness plug, probably because he also replaced as much of it as he could. It was a good splice, and I also tried another wire with a good splice. I also put some copper strands as shims inside the harness plug to ensure good contact to the board pin. So I think it must be the board, too. I get a used, working, identical part number board from a seller on eBay that I've gotten many good boards from.
I install it yesterday and get the exact same symptom. So it's probably not the board. I then tried another flame sensor. I move the flame sensor from burner #6 to burner #5 so it gets hit with fire just a little bit sooner. I bend the sensor to put even more of it into the flame. I get a good continuity on ground between the chassis of the flame sensor and all other grounds on the machine that I can think of.
If I let the machine go to lockout, I just get fault code 1 for ignition lockout. I do not get 7 flashes which would be low flame sense.
