I have read about systems being contaminated by "non condensables" due to poor installation. What exactly are "non condensables"?
millerman said:Things that don't compress well, like moisture and particulates. Compressors are designed to compress and move gas not solids.
Along with the good replies you've already received, the question you may wish to ask is what the significance of "non condensables" are.wendel said:I have read about systems being contaminated by "non condensables" due to poor installation. What exactly are "non condensables"?
How do you get oil in the lines?nwroc said:Why installing ac you could get air , oil , moisture in the lines.That is nocondensble.All sorts of problem then.
Exactly, moisture is sometimes confused with non-condensables because it is present in air, which is the major non-condensable seen in systems. Moisture causes it's problems by other methods, ie corrosion, sludge formation, acid formation, iced up metering devices, etc.bwal2 said:How do you get oil in the lines?nwroc said:Why installing ac you could get air , oil , moisture in the lines.That is nocondensble.All sorts of problem then.
How do you get it out?
Moisture is NOT a non-condensable.
Neither is oil.
