KMC series reset control
NC damper actuator
NC PE switch
KMC RCC-1112 reversing relay
KMC RCC-1108 high pressure selector relay
Barber Colman THR-1001 DA thermostat
This is a new box and I was told the factory set up the controls. I went to do the start up and it was heating regardless of the set point. I teed in some tubing, that was not connected, that went to B on the high pressure selector relay. It is teed in with stat B and T on the reset control.
The box will cool when demanded but will not heat. Can someone explain the operation of the reversing relay? A piping drawing would be good to have to verify it is piped correctly. Any advise is appreciated.
NC damper actuator
NC PE switch
