1 - 5 of 29 Posts
pony
· Professional Member
Joined
Discussion starter · #1 ·
HAVE CUSTOMER HAVE AHEAT PUMP CONDENSER,AND HE WANT MAKE HEAT PUMP AS STRIGHT AIR,USE GAS AS HEAT SOURCE,I TOLD HIME,I HAVE TO DO ALITTLE RESEARCH,I WAS GONNA JUMP ORANGE WIRE TO YELLOW,AND MAKE THERMOSTAT IS SET ON CONVENTIONAL,SO WHEN IT CALL FOR COOL IT WILL ENERGIZE COMPRESSOR AND REVERSING VALVE(COOLING ACTIVATE)ALSO,IS OK TO DO THAT?
Discussion starter · #3 ·
THAT I DONT KNOW IT , I KNOW IT WILL BE NORMAL SET UP WITH DUAL FUEL,BUT OWNER BELIEVE IN GAS FURNACE HEAT BETTER,BUT MY QUESTION HAVE NOT BEEN ANSWER,I BELIEVE IT WORKWITH O JUMP TO Y MAKE IT INTO STRIGHT AIR AC,JUST LIKE TO GET A AGREE ON IT.THANKS.
Discussion starter · #10 ·
BELIEVE IT WORK ALSO
BELIEVE IT WORK ALSO USE CONTACTOR TO ENERGIZE REVARSING VALVE,BUT WHY SPEND MORE MONEY IF JUST CHANGE PEICE WIRE WILL TAKE CARE OF IT?THANKS,ALLWAYS GO TO CHEPEST WAY AND MOST EFFECTIVE WAY,
Discussion starter · #21 ·
put thermostat on convention mode
if u put ur thermostaton convention mode,so it wont call for y,will call for w,thanks
1 - 5 of 29 Posts
