1 - 7 of 7 Posts
fireye03
· Professional Member
Joined
Discussion starter · #1 ·
can someone please help
traulsen m#ari 2-32lut
S#222358 8h
does anyone part numbers for the condensing unit,cap tube and ll drier
its an old r12 unit thats been converted to 414b called traulsen/hobart and my 10yr old son can give me more info.
i would assume the new condensing unit would require 134a the old r12 name plate says 21oz what would a 134a charge be equivelent to that.
god you guys are awesome.
thanks for the help in advance
btw HAPPY NEW YEAR !!!!!!!!!!!!!!!!!!!!! to alll
That ain't no conversion -
The 414 just drops right in. So replace the condensing unit with a like-HP R-12 unit, size the cap tube off Supco's R-12 chart, use a standard LL drier and you're off to the races.
PHM
S#222358 8h
Save
PHM
:ditto: Don't bother to convert a unit off this age. I have been using 409A for these mainly due to the availability of refrigerants.
Save
Hello there an Happy New Year to all of ya...
Just finished up an older one Today that some " TECH" worked on it previously and installed incorrect cooler side compressor and cap tube.
Traulsen 1(800) 825- 8220 Tech support
They will need to go into the file cabinet to get your information, but they will help you. mine was combo over 25 yrs old and now running like a rabbit.
Also as previously stated stick with 409a
Hope this helps any more questions let me know, Have a good one
Save
1 - 7 of 7 Posts
