About a month ago I had my XB16 AC compressor removed and replaced with an XV18 heat pump and matching TXC coil, 1050 stat, etc. It works fantastically well, but the last few nights it's started doing something I can't figure out.
When the compressor shuts off from heating, after about 30sec we'll hear a loud repeating banging sound from the whole system. It almost sounds like when you hear water hammer in your pipes from something like a lawn sprinkler valve shutting off, but it happens at about 2-4 "bangs" per second for about five seconds. I was able to reproduce it tonight while I was standing near the indoor unit (outdoor unit is on the other side of the wall so I could hear it too), and it sounded like the sound was coming from everything (indoor, outdoor, lines, etc.). I grabbed onto the lineset while it was doing it and could feel them thudding along with the noise.
I can't imagine this is normal operation, since it's loud enough to probably wake up people sleeping in rooms near the system. Does it sound like anything obvious that I should raise with my installer? I'm fairly certain it's charged correctly since he knew I was a tech nerd and walked me through the charging process as he was doing it and matching up the readings with the subcooling chart in the service facts document. For reference, the indoor and outdoor units are just about level with each other, and about 30-40' of line connecting them in sort of an upside-down U shape. Lines come in from the exterior wall penetration, go up to the ceiling of the mechanical room to run across the room, and then drop down to where the coil is located. Not sure if any of that matters at all.
Thanks a bunch for any wisdom you can share.
