The contractor/owner has text me and will be replacing TEM3 air handler with a TAM4A0A36. However, out of three (AHRI# 7419657, 7482692, 7553520) AHRI matches for Trane XR14, 3 ton, 14 SEER, HP model 4TWR4036, no mention of TAM4. I'm assuming it is a Hyperion XR 4 (17.5in width) model?
The width of our air handler closet space is around 24.24in, so probably eliminates the other two AHRI air handlers (TEM4A0C36 and TM4A0C42) which have 23.5in width. I didn't see the TAM4 as a AHRI match, but the width of of 17.5in will fit in the existing closet space well. He also agreed to exchange the pad with a larger one. He also stated that he can adjust the blower speed with the TAM4 so that the air isn't coming out as powerful (the TEM3 now is 50% more power/noise than our old unit) and a lot louder and powerful then my aunts 4 ton American Standard (not sure if it's a variable speed). Contractor did state that he can adjust the fan blower speed on the TAM4 to our liking.
Although I am glad that the contractor whom I trust is working with us, I'm not sure the TAM4 is a AHRI match?
And, if it's ok to use TAM4, I hope it is a better model than in regards to efficiency.
Any suggestions...
Thank you.
Any suggestions...
Thank you.
