Has anyone ran into many 410a split systems in which the installing contractor has "Soft Soldered" the lineset connections instead of brazing them? I have followed behind particularly one installer who also does a little "plumbing" who soft solders everything. I have seen some R-22 systems installed with soft solder, had the condenser plug up with cotton wood fuzz and run hot enough to where the solder joints leaked seriously. It doesnt seem like they can get hot enough to melt out the solder but I have had more than one with a very dirty condenser, and soft soldered linesets where I have had to correctly braze in the lineset because of the solder joints leaking. As bad as these were leaking I cannot believe it was a bad solder joint to begin with but then again I could be wrong. I have not had any 410a systems with this problem yet but most of those I have seen are new and have clean condensers so far, will see what happens once they get a little restricted!
