Finally got time to take measurements of windows and look up floorplan and survey information to attempt a load calc. Decided to use coolcalc for the mapping tool although I had to tweak the adjustments to get it close to what my floorplan showed. I know it is far from perfect but it's a start. I didn't make many adjustments to their assumptions except for noting things like concrete slab, ductwork in attic and other things I could easily discern. I don't know my insulation values, but coolcalc supposedly makes intelligent assumptions based on property records and code. I did take measurements of windows and sliding glass doors since we have a lot of window surface area that is all single pane.
I setup two systems to reflect the space covered by my two existing systems, and the results are attached below. The 5 ton unit (covers system 1) is the one supposedly with a freon leak that I have been getting quotes to replace. Not sure if that was the right way to do it, but since there are two system already in place I thought that would be best to reflect how the two system split the area of my house.
If anyone has feedback on adjustments to the calculation so far, please let me know. Based on sensible cooling load divided by 12,000, it would appear I need a 4 ton unit (system 1) and a 2 ton unit (system 2). However, I am not sure how to factor in latent cooling load and heating loads. What are your thoughts pros?
System 1:
System 2:
Existing Systems:
Installed by builder in 2005
5 ton unit
serves about 2700 sqft
Coil unit – TXC065S3HPC0 manufactured 10/2004
Gas furnace – TUD120R9V5K
Condenser – 2TTR2060B1000AA manufactured (unreadable label)
Filter media BAYFTFR24M
2 ton unit
serves about 1000 sqft
Coil unit – TXC031S3HPC0 manufactured 3/2005
Gas furnace – TUD060R9V3K
Condenser – 2TTR2024A1000AA manufactured 4/2005
Filter media BAYFTFR17M
System 1:
System 2:
Existing Systems:
5 ton unit
2 ton unit
