1 - 20 of 32 Posts
patriotsrule
· Registered
Joined
Discussion starter · #1 ·
sorry i dont know much, i got sent to one of those useless cfc classes that hand u a card for sitting in there for the day........ anyways i am hoping someone here could tell me the proper way to hook up a recovery tank and guages in cooling.a/c mode..... thanks for the help
He means the instruction book with the recovery unit. Most times there is instructions on the unit itself.....that's how I learned.
Save
Discussion starter · #5 ·
not to be a smart ass but if there was a diagram would i be asking ????? probably not or i would be brain-dead....... guys please i just started at a large housing complex and i need to know the proper set up of the guages, tank, machine.......etc. i got stuck in a cfc class where they give you a 100 notes and then the test was all those notes reworded to questions, they handed me a card but not real knowledge....... i would appreciate the input
i know the blue hose goes to the low side/fat line ..........
proper way to recover r-22
if you dont know how too hook up a set of gauges for recovery,then you shouldnt be messing around with it,call a professional
Save
At least
You know enough to say you don't know enough.
I'd go with looking up the machine on the web site, then I'd get myself into a school, if i were you.
drill a screw thru the suction line say oops and let the atmosphere take care of the rest.
Save
Discussion starter · #15 ·
wow last time i ask for advice on this site. thanks for being dicks and full of yourselfs. when you are done pulling the COC&% out of your mouthes then speak but dont give me sh!t for trying to learn the proper way to do something, just trying to follow the law.
OK, here do this.
Hook up blue hose A to unit, red hose B to recovery tank, green hose C to recovery unit, chartruse hose D to other ftg, Yellow hose D to other tank, and whatever else is left hook it all together. Turn it on and run.
Maybe you should have paid attention in class, oh wait, I forgot, you are too smart for that school.
Save
recovery
Take a look at the brand of unit you have and look on the web or ask at your local HVAC/R wholesaler for the company phone number. They also can put you in touch with the local manufacturers rep who can help you with booklet/diagram.
Some units can pump liquid, others vapor only. USUALLY you will hook up low and high sides to appropriate unit valves, middle hose to recovery machine, outlet hose of recovery machine to tank.
Other variables are: float switches (heaven forbid) push/ pull system (hopefully outdated by now)
In short...these machines use diffent techniques, so there will be no standard answers to this. You will have to find the company that made it in order to use the machine safely and correctly.
Remember one thing though: A bag of ice or a bucket of water is your friend when you are recovering refrigerant. Keep your tank cool and you will speeed up recovery (high heat = high pressure = slow recovery.)
1 - 20 of 32 Posts
