1 - 20 of 25 Posts
dmacdougall
· Registered
Joined
Discussion starter · #1 ·
Hi all,
I 've been recieving quotes on the installation of a heat pump to be added to my existing oil fired forced air central heating system. What I'm looking for is saving on heating cost. I have a 1200sq.ft house on a full 8' foundation which is insulated. The house is well insulated as well and has new energy effieceint windows and doors. I've been quoted a 2 and a 2.5 ton unit. Can someone tell me if this estimate is appropriate.
The average summer temp here in Easten Canada is 77deg F and we experience about 1 week a year at 90 to 95 Deg F . Winter average s approx. 25 Deg F Although we occasionally see a week at or around 0 Deg F.
Hi all,
A true and accurate load calculation is the only way to size the equipment.
As a side not make certain when the coil is installed on the top of the oil furnace that there is sufficient clearance for air flow through the coil.
Save
Hi all,
WHAT IS the closest town?
Grand Falls
St John's
Do you know how much oil was used for the last few Winters?
Save
Newfoundland and Labrador
ST JOHN'S A 47.62N 52.74W 463
99% DB /
___ MCWB WB / MCDB WB / ___ MCDB DP / HR / MCDB DP / HR / MCDB
___________________________________________________________ ___1% 2.5% 5% Heating DB Extreme Lat 0.4%
________________________________________________+__ 1% Annual W Dehumidification DP/HR/MCDB
_______________________________________________ ____ ___________________Long 1% / DB MCWB / DB MCWB ./ HDD / CDD 65
_____
3.7 7.6 . 76.3 65.9 / 73.4 64.4 / 70.8 63.1 / 68.5 / 73.8 66.6 / 71.1 / 66.5 99.3 / 71.5 64.8 / 93.3 69.5 / 36.1 / 30.7 / 27.6 / 8832 51
Save
If you want to save money find an meq Mitsubishi certified dealer and put in a zuba, ditch the oil and heat with the heat pump all year round and you should be paying about what it would cost to heat with natural gas. Most of my oil or propane customers are looking at a 5 year payback on the upfront cost
Save
What part is not true?
" A true and accurate load calculation is the only way to size the equipment."
Methodologies are:
1. Load Calculation
2. Testing of existing equipment or
3. Energy Consumption / Thermal Conditions review
of an existing thermal building envelope.
Save
Methodologies are:
1. Load Calculation
# 2 will only tell you the Btu output of the equipment not what the structure requires.
#3 will not tell you anything but speculation as to how much energy was used during a period of time. Without having a thorough data logging of all pertinent information such as ambient temperature, steady indoor temperature, run time of equipment and energy efficiency level of the equipment in reference
to how well the fuel was utilized.
In all essence # 3 is a load calculations when combined with #2 and all other pertinent data that is required.
Discussion starter · #10 ·
Grand Falls
St John's
I'm in Halifax NS which is more temperate than St John's. I used about 1750 Litres of oil = 460 US Gallons. However, a portion of that was used to heat water . I'd only be guessing but I'd say about 75 gallons for hot water.
Discussion starter · #11 ·
I'm looking for a ball park number. For example, worst case for a well insulated 1200 sq ft house with high quality windows and doors. Or what's the swing on 1200 Sq ft. Are you're telling me that the only thing I can do is a full analysis? Is any contractor doing an estimate, going to spent the time and money to do a full analysis at the quote stage?
It would be rather hard to give you an estimate if he does not know what you need. They could guess just like 90% of all others do and you would more than likely end up with a system that is to large.
You are probably on the 2 ton side
Save
You live alone. or wife and kids. 75 gallons for hot water seems low.
Save
Savings Estimate several $100s
Current oil cost ~ $1,500+
Heat Loss 24,000 BTUH
Heating Degree Days 7,840
HSPF 10
ATTACHMENT _ HVACOPCOST
Save
Save
jumpinjack 13, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
Your post has been deleted.
Further infractions may result in loss of posting privileges.
Discussion starter · #20 ·
Thanks guys. I'm starting over by asking for new quotes accompanied with calculations. I guess I'll have to become educated as well so I can understand what they're proposing.
1 - 20 of 25 Posts
