I have inherited the work for a chinese restaurant, mainly because I seem to be the only one around here that can communicate with the owner enough to have any type of meaningful conversation with him. Anyway, they have a walk in freezer that looks to be about 40 years old, the only tag on it says "Serial No 8915" and on the front above the door it says "Commercial Fixture Co. Indianapolis, IN"
I can't find any info on this company and and I need to find out what refrigerant it has as well. I don't have a lot of experience with low temp stuff like this so bear with me.
The compressor tag is wore off except for the oil it uses says "Alkabenzene oil" The metal tag on top says "7651 SC" then below that "10719" the below that "AH410ET-168"
All I found on the compressor using the AH410ET-168 makes me think it used R-12 but the oil makes me think that maybe it was changed, maybe 404A? I was running late and needed info on what I had so I failed to open the evaporator case to get info on the TXV ect. I will do that next time when I have more time to investigate. I had to defrost the coil to get it running and the low side runs around 10 psi and high around 120 psi. No sub cool reading, next time though.
Anyway, anyone have any info of the company that made the box or the compressor?
