Hi, live in the northeast and our furnace/ac in the basement is shot. We are converting to gas and replacing it with a new direct vent system, so the chimney will be used much less. There is another (already gas) unit in the attic for the second floor that vents out the roof already. So after our oil to gas conversion in the basement, there will only be a fireplace (which we may only use minimally, if at all) and the existing 4-5 year old water heater using the chimney. I’ve been told by two hvac contractors that I should still line the chimney with a stainless steel liner, but I don’t really understand why. Both of them don’t do that work themselves so I have no reason to believe they were trying to upsell me. So here are my questions:
1) do I really need to line the chimney? It’s already being used for the hot water heater.
2) if I do, would it make more sense to replace the water heater with a direct vent one instead of spending the money on lining the chimney? I think the cost is going to be comparable between lining the chimney vs getting a new direct vent hot water heater
3) or can I vent my existing hot water heater directly outside without using the chimney?
4) am I missing any other options?
Thanks all
Thanks all
