Hi all --
We live in a 10 yr. old Single Family Home in suburban Philadelphia, PA. We have zoned gas heat/AC, Lennox builder's grade split systems original to home. We run the AC consistently all season. First floor plan is open with 2 story ceiling through the middle of the home. Windows get late afternoon sun thru rear of house. Some mice decided to move into our 1st floor's 3 ton AC unit (what a treat) plus a freon leak was discovered, so we have decided to replace that AC unit, which has been shut off completely because of the stripped wiring. (Of course, forecast is calling for 90 tomorrow!) We just used most of the Federal Tax credit on new windows before discovering the AC surprise. We are down to two bids and could use guidance on the better way to go. Both are similarly priced.
Option 1: New Trane XLi 15 SEER AC and A-coil, new line set, pad, disconnect and electrical whip; 10 yr. parts and labor warranty.
Option 2: Bryant Condenser 126BNA036 (16 SEER), Bryant Coil CNPVP6036, Bryant Thermostat T2PAC01, incl. all duct transitions, condensate drain, refrigerant line set, condenser pad, plus all piping & wiring; 10 yr warranty on scroll compressor and all Bryant parts, 1 yr. labor.
My HVAC knowledge extends to the education I've gotten just through this process.
Which is is the better way to go? Thanks in advance for the wisdom...!
