1 - 7 of 7 Posts
flobiwan
· Registered
Joined
Discussion starter · #1 ·
I recently purchased a two story 2000 sq ft house in Ohio that was built in 1971 and I had a lot of work done on the a/c including a new unit and filter system. That being said, my main concern is getting cooling up to the 2nd floor in the heat of summer. There look to be a decent amount of supply and return vents on both floors.
It’s not yet hot enough to test but I’d like to have some sort of game plan in advance – It appears that mostly what I’ll be able to do to help is use ceiling fans and/or block certain vents in the summer. That being said, I came up with a few ideas – some extreme as I tend to think in extremes:
1. Block most or all of the supply vents on the first floor forcing more air to go to the 2nd floor
2. Block most or all of the return vents on the first floor forcing the 2nd floor returns to pull the heavier cool air up to the 2nd floor.
3. Combine 1 and 2 (definitely the most extreme).
So my questions are basically twofold:
In your best guess, what would be the best option of those 3 and are there any other viable options than what I’ve listed without tearing open walls and adding ductwork?
I understand if you block a lot of vents, it could put strain on the system and cause damage. How severe could the damage be? I ask because, if it works in getting more cool air to the 2nd floor, it may be worth it for me to pay more for routine maintenance and/or repairs depending on the cost. If i go that route, is there any specific maintenance i should have done on a regular basis?
Any advice or help would be appreciated.
If you want to replace the system then by all means block a bunch of airflow.
But seriously you can likely zone up vs down to a certain extent. I'd recommend hiring someone that can measure the static pressure while you are closing dampers.
Keep the static pressure in spec and you won't be damaging the system at all
Discussion starter · #3 ·
OK, i thought i was going to get an automatic email when someone responded to this thread. I guess i don't. At any rate, thanks for the reply. That's a good tip about static presssure. Now i know how to go about seeing what i can do without causing severe damage.
Best way is upstairs system in the attic. We do 1 or 2 a year in situations like this. 1.5 or 2 ton A/C, sometimes heat pump, little blower unit and a duct system. Ain't cheap but sure solves the problem and gives you comfort.
Discussion starter · #6 ·
I've thought about that if i can afford it. When you do them, do you have to change any ductwork or can you use the existing ductwork?
Also, could i leave the furnace in the basement and just have the a/c in the attic? Or perhaps have a second a/c unit in the attic in addition to the main one (maybe this is what you were referring to). It seems like that would be the best of both worlds.
Can you give me ballpark of how much that would cost me (I live in Cincinnati if that makes a difference). i realize there are a lot of variables but i'm just trying to get an idea.
And reduces operating cost while doing the other things.
PHM
Save
1 - 7 of 7 Posts
