Considering getting a home appliance plan for rental unit I have. Place was built in 2001 so things are started to go wrong here and there. I am looking at the contract book for AC and it says it only provdes "Limited leak repair" and is defined as leaks that do not require pump down and/or receovery (not opening the system). I assume this means they dont fix if it is the condensor or inside the unit, but will fix any lines outside? Question is then when there is a freon leak how often does the fix need to be "pumped down". I just don't want to be paying for a service that most likely won't be covered in their plan.
