My Inficon D tek Select died. Looking for new leak detector. Considering buying Inficon again. Just want to ask if there is anything better on the market right now? What do you, guys, think about Fieldpiece leak detector?
I have been using the INficon D-Tek Select since it was first introduced, I do admit there were some issues with the very early design but inficon quickly worked on correcting these issues. In the past I have used everything from corona discharge, Ion pump, heated diode, and Infrared. I must say I have always liked the heated diode units for many years until the blends became so used. Since the blends I had to get away from the heated diode simply because the blends would kill the heated diode sensor so quickly that you always had to second guess yourself or try a new sensor to be certain, this became very costly at $50 bucks a pop.My Inficon D tek Select died. Looking for new leak detector. Considering buying Inficon again. Just want to ask if there is anything better on the market right now? What do you, guys, think about Fieldpiece leak detector?
