Hello, I am a homeowner with a furnace issue that I am hoping someone on here might have some insight to. I have a 2 year old ICP SmartComfort furnace with a slant coil, in combination with a heat pump, that is all of a sudden pulling water off the evaporator coil and not going into the drip pan. It's falling onto the blower and spraying everywhere. Came home to water all over the floor around furnace. Called a HVAC guy and he thought it was a plugged drain line so he cleared that (did seem like it was a little clogged by the suction). Didn't solve the water issue. Coil is very clean, filter is new, no dirt or debris anywhere. Nothing wrong with drip pan. Checked coil temps and all were within a degree or 2 from each other so not a charge issue. Lowered the fan speed to low, still same problem. My HVAC guy called others in the industry for help and no one had a solution so I was hoping someone on here may have run into this problem before and would know what would be causing it.
