no, no, no, pressure testing is way to go.
John Dalton, (skip right to last paragraph for digest of this post)
I enjoy reading your interesting and well thought out posts, however, please allow me to disagree without being disagreeable. In short, I disagree with your supposition that , "...the 500 micron hold test is the “preferred test” of “educated technicians” ..." While I'm educated, I am by no means an experienced tech. Since I am next to worthless as a technician, please allow me to dispprove your supposition in lieu of any other useful information I can offer to this forum. lol.
For those of you that are sick of reading the math, just skip to the last paragraph for my clincher ending! It really says it all anyway, without the babble in between.
Here is the summary of your supposition, pasted here, just so were on the same tangent:
Perferred Vacuum Method: 760,000 microns / 500 microns = factor of 1,520 ( phenominal, as you say )
I Pressure Method: 200 PSIA / 14.7 PSIA = factor of 13 (rounded) ( inferior as you point out )
Lets restate the two equations in their factored form (i.e. 1520 and 13 being the factors)
1520 (factor) x 500 microns = 760,000 micron
13 (factor) x 14.7 PSIA = 200 PSIA
Lets make this even easier for everyone and restate the values in bare bones microns, instead of PSIA. Hence;
Vacuum 1,520 (factor) x 500 microns = 760,000 microns
Pressure 13 (factor) x 760,000 microns = 9,880,000 microns
The pressure difference between the inside and outside of the circuit might be a factor of 1,520 or even 3,000 (if you compared to 250 microns vacuum), or even a factor of billions if we used 0.000001 microns as our unit of measure, or even factors of trillions and giga-zillions, and tera-quads, as we approach perfect vacuum, ( I like Star Trek), but in all cases, the maximum difference will never be more than 760,000 microns, (more or less).
So 1520 x 500 microns, or 3040 x 250 microns , or 1,000,0000 x 0.00001 micron (whatever) , are all just another way to say essentially the same value, that is, 760,000 microns, more or less. Keep in mind that 1,000,000 times 1 millionth, is still equal to only 1. With your method, the larger your factor, the smaller the unit.
And of course, I claim that when it comes to the pressure test method, it's easy to see that a whopping 9,880,000 microns is a 10+ times greater actual pressure difference than a mere 760,000. Rounded out, 10 million, or 1 tenth of 1 million. Which is more? Factors, regardless of how infinately large, play absolutely no role in determining pressure differences in a circuit. With enought pressure, the copper line will explode, but in a perfect vacuum, with a factor of a million times 0...0001 microns, the copper line will not implode. Referring to factoring is a convenient way to convey the scope of differences to others when the absolute values are not known or too large or too small to be meaningful to the topic. The use of factoring can be misused intentional or accidentally in reporting, and should never replace actual values.
This reminds me of the way government reports put a spin on everything, such as; 'unemployment is down 10 percent...' (a factor of x (10). While that sounds optimistic, it is meaningless information. Unemployement could be down by 10 people or 100,000 people. Percentages and factors are a good way to skew reporting in someones favor since they ignore actual values, which are the real empirical evidence needed for calculations.
And lastly, as indisputable evidence, with your vacuum method, a vacuum of only a mere 50,000 microns (barely a vacuum at all ), will have a factor of 14 ! (760,000 / 50,000 = 14) And since 14 is higher than the factor of 13 that we get with 200 psi of pressure, then your suggesting that even a light vacuum is superior to high pressure testing. Do you think that a weak vacuum of 50,000 microns is a better leak test than 200 psi? Just a rhetorical question. I rest my case, your honor.
I submit this argument with all due respect, and I'm sorry that I am poor at injecting humor into my posts, as I see everyone else is so good at.
