I have my condenser installed in a nook that is on the ground level with my bedroom on the floor above.
Vibrations can be felt on the legs of the stand, but if I touch the feet of the stand I dont feel it.
I dont know if noise is just getting trapped between the wall and the condenser and traveling up or causing vibrations in the wall or if the pipes entering the wall are causing the vibrations, but this is annoying. Its only really noticeable on really cold days like sub 30F when the compressor is working hard.
I have reached out to vibration isolation companies since I thought it was for sure vibrational since if I open up the window in the bedroom all I hear is the fan, but they suggested that maybe its the pipes or maybe is just noise vibrating the walls.
They suggested first throwing a 1" thick waffle under each leg.
Would spray foam around where the pipes enter the house in the basement fix any pipes from rattling the walls?
Has anyone dealt with this issue before and solved it? I dont know why its bothering me so much, I used to sleep with a window ac in the room and that made a lot more noise. So far all I can do is put a fan on and drown the noise out that way.
Here is my house with the condenser location shown for some clarifications
