Steam systems need to be blown down 30 days at the run: sludge needs to be flushed because constantly adding new water, minerals from water, oils are always there from installation or repair of steam pipes (unless properly skimmed.)
Hot Water systems, properly installed, should never need flushing, purging or water replaced, in fact could be determential.
"Been There" was correct, you did not give enough information on which to advise one way or the other. The upper two comments reflect this.
