just a curious question
I installed radiant barrier in my van, and it has made a huge difference....Trying to deal with attic heat by ventilating the hot air is backwards anyway. Most of the heat that enters the attic is radiant heat from the roof. The hot air is what you get after the radiant heat energy heats all the objects and surfaces in the house. The objects and surfaces then transfer some of the heat to the air.
If you really want to make a HUGE difference, block most of the heat from entering the attic in the first place.
Have a radiant barrier installed on the bottom side of the roof deck. Foil is the most effective, but a good spray on barrier is usually the most cost effective as a retrofit solution.
http://www.ornl.gov/sci/roofs+walls/radiant/index.html
http://www.eere.energy.gov/consumer/your_home/insulation_airsealing/index.cfm/mytopic=11680
Air is dumb, it doesn't know that it is only supposed to come in through the vents you supply for it.I have always wondered about that...it makes sense about the PAV pulling conditioned air up thru the attic and ventilating it to the outside...That would definately be a concern if you had too much cfm and not enough vent space to draw the air from, it would suck air from the 1st or 2nd floor up thru the attic...
Prodex foil-foam-foil purchased from www.insulationforless.comNeophytes - do you remember what brand/style you used in your garage rafters?
..........The study's authors looked at several weeks of similar weather before and after the retrofit. Once the fans were in, the daily peak attic air temperature dropped by an average of 22°F. Air conditioner energy use was also measured. This consumption was reduced by an average of 6% (2.8 kWh per day) by the addition of the ventilators; the difference was greatest around midday. Space-cooling electricity use, which had been submetered at the home for the entire year before the retrofit, totaled some 7,730 kWh. Annual space-cooling savings are on the order of 460 kWh, based on extrapolation from similar periods. These savings have a value of about $40 at current Florida energy prices. Given that the installed cost for the two units was about $850, the payback period would be more than 20 years. The homeowner did note that the interior seemed more comfortable after the retrofit, even with no adjustment to the thermostat. Generally speaking, however, it seems that other means of controlling attic heat gain are preferable and more cost-effective than forced ventilation
