I am looking for the downside effects of using DI water in a open tank chiller.
Is their any?
Is their any?
No Glycol, just DI water, DI water is Deionized. Distilled isn't the same.Is it straight water in this open tank chiller, or is there glycol and/or other chemicals mixed in? I would think if there is glycol or other chemicals in there then the distilled water would be a good thing.
If it's just water, theoretically the distilled water might cause issues with rusting/corroding faster than tap or other water with minerals in it would.
What is the application/what type of chiller is this? I think the only open type chillers I have ever seen (besides drinking fountains) were for keeping beer lines cold. Is this a small system like that, or is it a large chiller used to cool down a building?
You got me curious, so I looked up the difference between deionized and distilled water. From stuff that I just read I learned that DI water is very corrosive and can eat through pretty much any metal including copper and stainless much easier than "normal" water can, so I guess that might be a downside.No Glycol, just DI water, DI water is Deionized. Distilled isn't the same.
It has (3) brazed plates, but it also has copper and brass in the system, so the DI will cause corrosion. They even went to the extreme of installing a EC transmitter in the loop which will open a solenoid to a deionizer, which will assure the water is pure.What size is this setup? Maybe use a brazed plate heat exchanger? Sure it's another pump but it would eliminate any issues with the chiller
Is their any?
From my research, DI will eat the copper. Their is copper in the system.What will prevent the DI water from corroding everything it touches? Is the chiller built to withstand DI water?
PHM
DI Water Compatibility ChartFor DI water you can use copper. But better is just stainless (304 or 316) on the DI side and as stated a mixed resin bed is needed to maintain the water pure. Maintenance on the system needs to be much more frequent than a standard chilled water system. Large generators like in power plant use DI water for part of the cooling because the electrical resistance is very high. However the DI water nedds to be highly oxygenated or contain very low levels of oxygen. DI when oxygen levels are high or very low the ion tranfer rate is the least, which is probably why the open tank is being specified. The mixed resin bed probably will not last very long. If there is copper in the DI loop when the resin bed is opened; if there is green or blue green colorseen in the resin that is copper. The cyclotron guys are going to have to inspect their equipment on a frequent basis for copper bridging. Copper bridging betewwen energized components creates an electric circuit
