Hey there,
We're continuing to get bids on how to improve the big temperature difference between the first and second floor in our 1920s brick home. I posted about it earlier here but since then I've gotten an interesting fourth bid and done some digging on my own.
First, my digging. I've studied my (very old) duct system a bit and realized that there are only three 12"x4" supplies going from the basement to the second floor, each in a joist cavity. If you look at the blueprint I've attached there is one line supplying the blue registers numbered 9 and 12, one supplying the registers numbered 10 and 11, and one supplying the register numbered 13. (There are no returns anywhere on the second floor.)
Given the lack of air flow it's clear that we're going to have a hard time making the second floor more comfortable. But that's where this fourth bid comes in. The first three bids did not look at my existing ductwork and did not mention doing any insulating or airsealing -- it was immediately "Slap a second AC in your unconditioned attic." But this fourth bid suggested I try some smaller steps first. I was intrigued by two of them.
1) Adjust the dampers on each supply line in the basement, near the plenum. In particular, reduce the downstairs dampers in the summer to force more air to the upstairs.
2) Put an inline fan in the supply that goes to registers 9 x 12 -- and not a cheap galvanized metal fan but something like a Fantech FR150, which can move around 200 CFM. He would put in a pressure switch so the fan would turn on with the main system.
I have two concerns. I've read posts here that suggest messing with dampers can eventually cause problems with your coil freezing. And I've seen a lot of skepticism about inline fans -- that they're bandaids and that they can cause problems elsewhere in your system.
So I'm curious to see what you guys think of this contractor's plan. First, can the dampers cause problems for the coil even if we're just reducing and not fully shutting off the supplies downstairs? And second, is the inline fan worth trying for that one upstairs supply? The two second floor ducts connected to it are by far the weakest ones in the house (and most important since they hit the master and the nursery). It's also the longest run for the upstairs. So I'd love to get them more air and wondered if this was worth a shot.
