Need a little help.
Working on a job where the original white box spec called for a 15 ton heating/cooling RTU for a single story office space. Unit is installed (no ducting), now a tenant is found and their specs call for a "constant volume system with electric heat duct heaters in ducts that serve exterior zones"
Pretty straight forward office area with large open interior area with EXTERIOR zones as conference rooms, private offices and lunch room. They are asking for (6) electric duct heaters to serve each individual exterior area.
Wondering how a system like this works? Where does the MAIN t-stat get located for the RTU? I would gather that the main t-stat is located in the interior zone and that it functions like any single RTU/t-stat would (call for heat, call for cool, entire system gets hot or cold air).
Now, I assume that the electric duct heaters are for providing heat to those exterior zones when the interior zone (where t-stat is) is calling for cooling when exterior needs heating. Also I would assume that those electric duct heaters could provide additional heat (booster coil) when the RTU is in the heating mode?
Do these electric duct heaters have room sensors to control their operation?
Lastly, if I am on the right track, what is the proper way of sizing the electric duct heaters?
Thanks for the help!
