Greetings, first post here.
I have an L shaped 1 1/2 story house with the garage and bonus room at a 90* angle to the main part of the house. The bonus room is approx. 395 sq ft. It has 2 dormer windows that face South West and get afternoon sun. The bonus room is accessed from stairs off the kitchen, and it is separate from the other 2 bedrooms upstairs. I cannot post pictures, but if you googled Frank Betz Rosepark, that would be my house plan, only reversed.
The house is located in North Georgia.
There is one 1.5 ton hvac unit that serves the upstairs (the 400 sq. ft. bonus room and 550 sq. ft for the other 2 bedrooms / bathroom). I think the bonus room has a 8 or 10" supply split off to 2 6" runs and a return.
Last summer, there were days that I could not get the room any cooler than the upper 80's.
I've gotten a couple of quotes for a mini split. The first guy told me 1 ton would be enough, and he planned to cap off the duct work to that room. I told him I wanted at least 1.5 ton to be on the safe side.
The second guy recommended a 2 ton unit right off the bat. He also said he did not want to cap off the duct work for fear it would choke the current system too much.
Both quoted prices on Mitsubishi mini splits. The 2 ton was a 7 year warranty and the 1.5 ton was a 12 year warranty. the part numbers are MSZ-HE24NA / MUZ-HE24NA for the 2 ton, and MSZ-GE18NA-8 / MUZ-GE18NA-1 for the 1/5 ton.
The room is almost 26' long with a sloped ceiling on each side. Both contractors want to put the unit in the center of the room as high up as possible. The ceiling slope begins at about 70" off the floor, so that is the highest the unit can be mounted.
I didn't have any knee wall access originally, but in the last week I put a 2' 0" x 3' 0" door on one side. There is R-19 insulation laying on the garage ceiling and it's turned up at 90* under the knee wall, I guess to try to make a block from the knee wall area to the garage. The joists are 14" deep, so there is a big gap between the insulation and the bonus room floor. I hope this makes sense.
The knee walls themselves appear to be fairly well insulated with what I believe to be R-19 ( it protrudes quite a bit from the back of the 2" x 4" stud). Although, there is no sheathing on the walls, which I read might help the situation.
That's about it. Any thoughts or suggestions on how to make this room more comfortable?
