I was called out to a job in a condo building on the second floor of three total floors, located in West Palm Beach, FL. Their A/C unit had been having issues for months with the condensate drain line backing up and the Safe-T-Switch on the air handler being tripped. After the drain line was cleaned the problem seemed to go away, this was on an off like that till I was called out a few weeks ago. The reason they ultimately called was one of the fittings got broken and the drain line was leaking.
The unit is on a shared drain line. I blew some condensed air into the shared line to make sure it was clear. Then I replaced the P-Trap with a clear inline trap and the unit seemed to be running fine when I left. When I finished and had the unit running their A/C was the only one running and water was dripping out the condensate line outside. I received a call from them later that evening saying the Safe-T-Switch tripped again. They told me it happened while the shower was going and dinner was being cooked and that the unit was draining ok under normal use.
I went back out thinking the trap wasn’t deep enough I built a quick P-Trap and installed that and I also installed a vent pipe which the drain line didn’t originally have. I turned the air way down and drain was working fine, I stayed longer this time to make sure. Got a message from them later with the same result, under normal use was draining fine but if you start showering cooking etc. anything to produce a bunch of humidity the drain line can’t keep up and the switch trips.
They had to go out of town for a couple weeks and just got back and we chatted. The drain pan had filled up and even spilled over a bit. The humidity had climbed to about 70% in their place, they cleaned out the pan and ran the unit, while running the unit they had to keep cleaning the drain pan which is now overflowing even during regular use.
Could it be that someone in their stack put a positive pressure system in?
Did I screw up on the P-Trap and the static pressure is too high?
At this point I am at a loss… What could it be, but more importantly, what should I do?! Thanks
P.S. I have pics of the install if needed.
