21 - 24 of 24 Posts
Off-Cycle Defrost is a standard concept
This is why, when designing refrigeration equipment installations, you use a 16 or 18 hour cooling day.
As opposed to an A/C project - where you have 24 hours to take away the heat.
In refrigeration design you don't have all 24. The reason is because of the need for defrost of some kind.
Either off-cycle defrost or an active, added heat, defrost of some type.
A 38 degree box temp. Standard 10 degree delta. 28 degree coil. Frosted coil.
Save
Discussion starter · #24 ·
If evap temp is below 32, you need a defrost of some sort. It may only have an extended off cycle, but that is still a defrost.
Checked cooler today. Everything seems good. Watched it through 2 on-off cycles, 1 from box and 1 from rooftop. Stlll 12 deg superheat at evap and 25 deg at compressor. Little bit of ice forming on dist tubes a few minutes before box reaches temp. No visible ice on evap fins. Ice dissipates seconds after shutdown and evap fans run continoulsy, so I guess thats it's defrost cycle. It has apparently has been that way for 25 years. Amps=1.84-1.87. Pulls 2.0 amps at startup for about 2 seconds then down to 1.8. Thanks again everyone for all the info. Jay
Save
21 - 24 of 24 Posts
