1 - 15 of 15 Posts
DDCman
· Registered
Joined
Discussion starter · #1 ·
Need Circon and TAC plugins for LON. Have new Circon plugins from Engunity, but older are not listed. Need all you have from TAC.
Can anyone help???
Please!!! :confused:
#1. You have no contact information.
#2. Where did you buy the TAC products and why can't they get you the plug-ins?
Save
Discussion starter · #3 ·
We are working on an existing project with Circon and TAC controllers running on their respective front ends. We are integrating into Tridium and tunnling with LON thru Tridium, need plug ins, no coop from either Circon or TAC as uaual.
Anything else you need to know?
You still don't have any contact information in your profile.
Save
I believe the Circon plug-in covers all the 300 Series controllers of all vintages, except for the Basic programming function. Now if you have 200 Series controllers there is no plug-ins for them.
Save
Are you a TAC dealer or partner?
Thenyou should be able to access there web site and retrive all the plugins that you would need for this procedure.
The circon plugins are dependent on ther version, the only way to look at the 200 seires is thru there Circon's front end and there programming software, that is System Intregrator.
The 300's have the xif built into them and should be on the workstation onsite.
The oines from Engunity should be able to use on the 300's.
Lontshooter
Discussion starter · #8 ·
Thank you all for the reply, we have solved the problem partially thanks to you all.
I guess CRAB must run the show here as his only response was that I do not have a profile listed, sorry budm but that ius the way it is! Thanks for your non help!!!
First of all I don't run the show.
Second you just screwed yourself on getting the plug-ins from me. If you would have posted an email address in your profile I would have sent them.
Save
Save
1 - 15 of 15 Posts
