Hello
I would like now know if its possible to pipe in chilled water into the heating coils in the air handler be used as cooling?
A little background infomration, I have a commercial water chilled unit in a very hot and humid part of the country which is basically summer all year round. I think most of the HVAC equipment is original from the 60's except for the water chillers which are relatively modern.
For some strange reason, the original builders put in a lot of heating equipment that never gets used. In fact, I have had to tear out a lot of the healing equipment just to make room for my other more important things.
The HVAC is unable to keep as cold as I would like yet its not a problem with the tonage as the water chillers will periodly turn off then turn back on again when needed. I think its unable to convert all that chilled water into approperate cold air.
One of the ideas I had was to use the heating coils in the air handler as cooling coils by having chilled water run though them.
Again, I don't care at all about heating as I have scrapped heating equipment for space already. I just need to get things cooler by whatever means necessary.
Can the heating coils in the air handler be used as cooling, if chilled water was piped into them ?
Thanks.
Thanks.
