1 - 15 of 15 Posts
Discussion starter · #4 ·
Unfortunately I do not think we will have any relief until the new wells have been completed. Everything they have tried has been a monumental failure.
The relief wells are the permanent fix for sure...I just hate seeing all that oil gushing out every day and waitng for it to be capped better.
Save
I always tell my techs, "Try something even if its wrong." when ever they are stumped on a problem.
We as a nation can't just stand there with our hands in our pockets waiting for August to roll around. Who's to say the relief wells are going to work.
I second the motion. Good Luck BP on the latest effort.
At some point all three wells become one. That is the plan.
The first relief well is very close to the original well and the pressure testing of the blownout well will possibly comunicate into the 1st relief well. This could make the 1st relief well kick and complicate their relief efforts. I'm sure they are making all the safe decisions this time. They can't afford to have
2 or 3 blowouts.
Save
Discussion starter · #9 ·
Turns out our government has put the stop on the works until they look on the saftey issues further...hope these people have an idea of what they are looking for.They didn't seem to be around prior to this mess.
Save
I am starting to worry that this was the planned outcome. Someone on here probably knows more about big business than I do, but what would prevent BP from filing for "Loss of income" to the insurance company since their partners have basically told them to shove it up to this point? If that happens then our government foots the bill for this behind the scenes and considering that this has already cost BP over 90 billion dollars.
Discussion starter · #11 ·
They are testing the cap at this time and, for the moment ,the oil leak has stopped flowing. To be continued......
Save
The current testing of the capped well has engineers and scientists somewhat concerned and puzzled as to why the pressure is lower than expected. here's an excerpt form a report from the Associated Press:
Pressure readings after 24 hours were about 6,700 pounds per square inch and rising slowly, Allen said, below the 7,500 psi that would clearly show the well was not leaking. He said pressure continued to rise between 2 and 10 psi per hour. A low pressure reading, or a falling one, could mean the oil is escaping.
I was pondering this and after applying a bit of basic refrigeration I have arrived at a possible explanation for the lower pressure.
The main oil field contains a considerable amount of gases...ie, methane, natural gas, etc. All of these gases are likely mixed and/or dissolved in the oil in liquid form at equilibrium...much like the refrigerant oil mix we all see in a compressor crankcase.
In a crankcase, if we drop the pressure the liquid refrigerant begins to boil off, coming out of solution and as a result the whole mix cools down in an attempt to again reach equilibrium.
I see the same thing may have happened after 87 days of blowing off this oil/gas mix at a rate of thousands of barrels /day. I suspect the whole oil reserve has cooled to a point where the pressure/temperature of the mix is now well below what they expected. The slow rise of 10psi per hour is probably just the result of a slow reheating of the mix due to the surrounding earth's heating.
My bet is the well is OK...ie, no leaks.
Save
Discussion starter · #13 ·
That makes perfect sense ,Ice. The pressure slowly rising as it is now is what they should have expected. Hope they catch on and continue without a panic situation.
Save
1 - 15 of 15 Posts
