Hello,
I am looking to get ducts replaced in a narrow crawlspace. Original ducts are 1996, flex duct with the pink insulation and plastic wrap inside and out (black on outside, clear on inside). They are nasty and got infested by rodents. The house is in very very rural California mountains.
I would like to install rigid ducts, however a few areas are difficult for this and Alumaflex was mentioned.
Does anyone have experience with "Alumaflex" wrapped ducts? I can't seem to find a supplier that will sell me 1 piece and I can't seem to find a spec sheet. Can I just assume it's the exact same as the aluminum dryer vent duct at Home Depot just wrapped with insulation and foil on the outside? Does the installer need to stretch the duct tight?
I would assume I would need to tell future plumbers and electricians if they are ever down there, to NOT push up on the duct and crimp it, correct?
This will not be a DIY job. I just like to learn about what is going into my house to weight the pros/cons of $X dollars vs $Y dollars.
