Filters can only clean the "air" of what actually gets to the filter.If you have a big dust problem,you likely have a problem that filters won't solve.
For example supply air duct leaks ,outside the conditioned space,cause negative pressure in the home causing infiltration of outside air.Makeup air or repairing duct leaks will solve this.
UVC light is great for keeping the cooling coil clean,and free of nasty stuff growing there.
The Carrier Air purifier,captures and Kills mold,virirsus,bacteria etc., great because it's all dead and benign when you change the filter.Trane has the Clean Effects ,requires cleanung ,kills ,nothing ,but is a great filter.
EAC's work very well ,as stated when they are working properly.Shouldn't need or want an EAC and a pleated.
All better filters,except an EAC are much more resistent to air flow,so before adding insiste that the ESP(resistance of ducts to air flow)is tested ,to be sure your existing system can handle it ,and deliver the required air flow to protect the equipment!!
