I have a building with four Carrier 48AJ RTU's. I believe installed in 2005. They each have an ABB ACH550-UH 10 hp drive. There are nuisance trips of "overcurrent" on these units. Different unit,different day,dfferent time. I was told this has been happening since the building was built. I have worked with ABB tech support. I checked and changed perameters per their advice(Accel,decel,volts,amps,hp etc.) I have an active case number open with ABB. I have talked with them four times now. They even had me put slightly different perameters in two of the drives.The problem still exists. These units are on a VAV system. It seems to happen at morning warm up or during setback when fan cycles. They may operate for two months o.k. then fail twice in a week. Fails .....different unit,different days.But,typically only one random unit will fail. I usually go to the jobsite one day a month. The customer logs the failures and manually resets unit by cycling power. Any help would be appreciated. Thanks
