1st time doing a Walk-in freezer (New to low temp).
404a with TXV 6lbs receiver has LLFD.
ALL SH’S ARE TAKEN AT COMPRESSOR
Start out with SH 81 box found at +35 f sorry forgot pressure they seem ok clear sight glass evp and cond coils clean fans have good flow TXV would not dial in SH lower then 71 F TXV bulb on good
Recovered and weighed in charge of 7.9 lbs
Pull vacuum to 500 micron. Was told latter I should have gone to 250 and let stand for 12 hrs NEED TO GET IT UP AND RUNNING and was to schedule down time latter.
Charged (fresh 404a) to 6lbs per Heatcraft tech support sightglass clear
Took box hours (6 or 8) to get to temp –10 F from starting temp of 42 F .
OA 71 F Hi side 182 Low 12 SH 51 can’t dial it down any lower.
{Recover tank saturation check next day show good}
I’ve scheduled it to be down this coming week thinking it’s clog in TXV strain?? Or Bad TXV head ? (not much throttling when bulb was warned hand then warm water )
Was told it had a burn out in the at six months and has been trouble all every since (3 years old building).
Question
1. should I reuse the 404a charge I recover
2. Tips on charging
3. Thought on what might be wrong?
Question
2. Tips on charging
