https://chicago.suntimes.com/2021/2...21/2/9/22275353/refrigeration-unit-leak-petes-fresh-market-gage-park-evacuation
A big fan unit to blow out the bad air?
:eek2:
:eek2:A Pete’s Fresh Market in Gage Park was evacuated Tuesday afternoon after a refrigeration leak.
A hazardous materials team responded about 4 p.m. to the grocery store, 5724 S. Kedzie Ave., after refrigeration unit leaked, Chicago fire officials said.
Readings indicated a “bad atmosphere” inside and shoppers and employees were evacuated to a nearby McDonald’s, officials said.
Crews were awaiting the arrival of “the big fan unit” to “blow out the bad air,” officials said.
No injuries were reported, officials said.
That still sucks tho. There was 3 Trane guys who got stuck in a fault and died from refrigerant inhalation. It was overseas somewhere.1 Tech from cimco
and
2 facility untrained persons
none were wearing their Respirator
When reporters remind people to test them they are saying to put it into test mode not to calibrate them as you are really suggesting.The same journalists that recommend testing your CO alarms. Where do people get the CO for testing?
The test button involves the battery and the horn. The sensor is not tested. How does that ensure safety?When reporters remind people to test them they are saying to put it into test mode not to calibrate them as you are really suggesting.
The reporters could tell them to throw the detector away without making them any less safe.The test button involves the battery and the horn. The sensor is not tested. How does that ensure safety?
Calibrating them which is what you are really referring to does not "ensure safety." Reporters reminding people to test their smoke and CO detectors is a good thing and they should continue doing it without people who should know better belittling them for doing so. Do you calibrate your CO detector? The sensors have a predetermined life as tested by UL.The test button involves the battery and the horn. The sensor is not tested. How does that ensure safety?
Smoke alarms are tested with smoke to prove they work.Calibrating them which is what you are really referring to does not "ensure safety." Reporters reminding people to test their smoke and CO detectors is a good thing and they should continue doing it without people who should know better belittling them for doing so. Do you calibrate your CO detector? The sensors have a predetermined life as tested by UL.
A CO alarm should respond to CO to prove it works. Pushing a test button does not proveit will respond to CO.
Leading people to believe that a CO alarm will protect them when the horn works is doing them a disservice.
A common UL Listed CO detector may or may not save lives. A Low Level CO detector Will save lives!I asked you if you calibrate your CO detector or let's say test it with CO. You quote my post and don't answer?
I bet you sell CO detectors and or go on and on about them to your customers as you do here. Do you test them with CO? If you do sell them do you include a can of CO spray, if not why not? If you don't do that do you test it for them twice yearly?
It is surprising how many people do not have CO detectors in their home and forget to change the batteries. It is a good public service to remind people of that and I feel sure many lives are saved because of this.
The common CO detector is designed to save lives and they do just that.
Sorry I am posting to the wrong post.Smoke alarms are tested with smoke to prove they work.
So you go from they may not save lives to you are not happy. I am satisfied with that retraction.I agree they “should” be tested with an approved CO Spray.
As far as proof I’m not happy when OSHA tells us 15 PPM for 8 hrs max yet a UL Listed will not alarm for 60 - 180 mins after the alarm reaches and maintains 70 PPM.
I said im not happy with OSHA saying one thing and the public being put in harms way. I'm sure there's plenty of instances where people suffered or even died because of the ridiculously high and long wait on UL detectors. Unfortunately the requirements are met and better then nothing, but not by much!So you go from they may not save lives to you are not happy. I am satisfied with that retraction.
I do have my combustion analyzer calibrated. I also wear a Sensorcon personal CO sensor. I don't know of ANY home CO detectors that can be calibrated. To which of these are you referring?I asked you if you calibrate your CO detector or let's say test it with CO. You quote my post and don't answer?
Change batteries in a detector they don't have? How is that even possible?It is surprising how many people do not have CO detectors in their home and forget to change the batteries.
Keep on moving the goal posts my friend. Going from they may not save lives to you are not happy to people may suffer etc... I agree that people may suffer from low levels but as I said they are designed to save lives.I said im not happy with OSHA saying one thing and the public being put in harms way. I'm sure there's plenty of instances where people suffered or even died because of the ridiculously high and long wait on UL detectors. Unfortunately the requirements are met and better then nothing, but not by much!
See post #33
thanks Vinnie :cheers:
A laboratory study at Ohio University showed that 25% of the detectors failed to respond (all with UL approval). Of the remainder, 25-30% responded too early or too late. That's an abysmal average.My highlighted sentence is correct. They are designed to save lives.
The average CO detector does save lives. Do you have examples where people died when a CO detector was working within guidelines as you seem to suggest?
Since that was all you addressed does that mean you agree with the rest of the post?
Hey genius many do not have them and many forget to change the batteries. I did not say what you imply.Change batteries in a detector they don't have? How is that even possible?
That doesn't answer my question or address your earlier post.A laboratory study at Ohio University showed that 25% of the detectors failed to respond. Of the remainder, 25-30% responded too early or too late. It's a roll of the dice.
