101 - 120 of 166 Posts
OP, you say an awful lot of "seen it many times" & " got 100's just like that" & "they can't ALL be wrong". How about some book knowledge mixed up in there somewhere.? Got milk? Got info?Then w/ some solid references we might start to listen to you and you might even help educate us. But Dude, not the "I SAW IT. I SWEAR!" way. Not with "this crowd"! We need proof, not jaw flapping.
He's not a Tech
He's a PM Grunt. I wonder if he works for one of those...……...He's breathing, He's qualified, Give him a truck and make us Money!
Discussion starter · #109 ·
What is that formula for figuring out Target Super Heat ? WB x 3 - 80 - ODAT / 2.
Lol i don’t have to prove shit to you. I still can’t believe you don’t think suction pressure is correlated with outside dry bulb temp. Did you retire when they were still using r12 or something?
Suction pressure will change slightly depending on exterior conditions or wherever your condenser is but the simple fact is that the system is designed to work within a wide range of ambient temperatures. It's not like your A/C won't work in the winter just because it's cold. There's components and features added to make up for such things.
IF your suction pressure is way too low, I don't care what temp it is outside, there's a problem that needs to be fixed.
The more you open your un-professional mouth the more stupid you sound. YOU CAN'T PROVE CRAP, CAUSE YOU ARE NOT QUALIFIED. that is obvious. Sure sounds like you did go at least one school, "The WAY OF HVACR & SNOTTINESS" by The GURU.
Why do you not have to prove to us what you claim?? WHY?
I must have gone to a different school for Thermodynamics then you did!
How does a Water Cooled (GEO) system operate with 55°condenser water?
Suction pressure is dependent on Temperature across the evaporator. At 50°f ambient you'd better have some type of head pressure controls!
Wait a second ... it's the Guru ? He'll I miss that guy he brought a lot of life and vigor here. Hundreds of pages of non-sense and circle talk.
Say it ain't so !
Discussion starter · #114 ·
There’s a reason why most user manuals tell you not to operate your AC when it’s below 55 outside. I’ve had to do plenty of checks were it was only 40 outside. I’ve seen suction as low as 30 psi and was fine that summer without putting refrigerant in
Discussion starter · #115 ·
Well that’s why when we re told to do pms in that cold of weather we can only run them for a few minutes. We can use the bag over the condenser trick but only on txv units
Yes there is a reason...……………………..
Why is that?
We run A/C & Refrigeration systems in all temperature and conditions!
Discussion starter · #117 ·
Because I know what I see in the field and what is normal and what is not. But then again all these hundred of units are all mismatched and undersized right. What do I have to gain by proving anything to you? Street cred in a forum? I must be doing something right if they put me on call and have had me doing PMs for years. Or maybe my company and clients are so desperate that they’ll take anybody right
