Hi,
I am adding two new rooms onto my house; one room is a 13x26 with one octagon window and the other is 7x10 with no windows. The two rooms are located next to each other.
I have done all the construction myself and since my budget was so tight, I decided to at least install the hvac and hire out someone to commission it. After a lot of research I purchased a Daikin fdxs12lvju concealed duct mini split. My original thought was that I could simply add a couple small flex ducts to connect each room and it would be done. However, I am now realizing that this unit's static pressure is so low, that it may not support my requirements. The static pressure is .12 according to the documentation.
The way my duct is currently, I have 3 - 5" ducts coming from the supply side of the unit. Each is about 20' long. This allows me to place one register in the small room and two in the large room.
I know you will all beat me up for not hiring it out, but I couldn't afford it so this is where I am at.
Does anyone have any good news for me?
I'm pretty much stuck with making this unit work and just have to figure out how to make it happen. Here are my questions:
1) Will the unit handle this amount of ducting as it is?
2) Would an in-line duct fan help get the air flow up enough?
3) If so, what "auto" booster fan would you recommend?
Thanks.
Thanks.
