I have a question with regards to LRA of a compressor or motor. What would be a normal range difference from what LRA/RLA that is printed on name plate? Example if I had a LRA of 40, but measured 38 amps on start up then drops to 7 amps and the RLA is said to be 10, would this be acceptable? And what breaker would be acceptable if the name plate says a 15amp max breaker? It seems that a 15 dual pole breaker is to small, if on start up its pulling 38 amps...
:det:
:det:
