Buy a UEI
And you just might DIE
I've had a UEI DL-250 for at least 5 yrs and I really like it. Same model, but one before that quit reading either capacitance or the flame sensor reading, it was just before the 3 yr mark so sent it back and they sent me a new one. So been using the UEI for around 8 years.
Personally I prefer the amp clamp style multi-meter. Got a fluke 28 II w/the accessory amp clamp but the thing is a tank. The meter itself it big, then add the accessory amp clamp which is almost half the size of the meter. Next the amperage readings take forever, you can watch it slowly climb and then once it stabilizes you actually get a reading. Literally like 10-15 seconds at times. My UEI, clamp it on and within a second/maybe two you have the correct amp value.
Definitely prefer my more compact UEI, but needed a meter to also read 4-20 mA signals, only thing the UEI won't do.
On guys getting zapped, I don't just trust my meter, I also trust my screwdriver - "If it's not grounded, it's not dead" kind of thing. As mentioned leads can be bad and no meter can compensate for bad leads.
Back to the OP - the local Johnstone is selling a UEI DL 379 for a very reasonable price. Granted almost 4x what your wanting to spend, but for all it does -
http://www.ueitest.com/productList-clampon.html Also that give you another temperature sensor on the meter as well.
Looks like it is going for just a bit more than the 369. The website is also showing a possbile 7 yr warranty if you register it, otherwise it's a 3 year warranty.
