Hopefully I'm violating the forum rules here. I don't plan on fixing this myself, I just don't understand the issue. My AC unit was freezing up (inside the air handler unit and also the compressor condenser coils outside). I called the tech company I've used for years and he came out and said I was low in freon and most likely had a leak. He also predicted it was my evaporator coil based on the look of them (a fair amount of rust at the edges). He got his leak detector out and found a very small leak at one of the connections to the evap coil. Put some yellow goop on it and we could see small, slow forming bubbles. He told me I needed to either get the coil replaced or replace the entire air handler. A pointed out the leak was right at a solder joint, so why not just gob some more solder on it to try to seal it? He said that would not work, that he'd probably damage it by trying to repair it.
I'm not an AC guy by any stretch of the imagination, but if I had the tools I'd certainly take a crack at fixing that connection. I assume he'd probably have to evacuate the system, solder the leak, then refill.
Am I completely off base here?
Thanks for any responses
