1 - 8 of 83 Posts
What is Trane using a rotary in? Besides minis and they don't build them anyway, the Chinese do :(
The unit we are installing next week has a Samsung rotary in it and it is a 2.5 or 3 ton XB I think, will know more when it comes in. It may not come to fruition but with it going to field testing it is very likely that it will.
So you say this is a field test for Trane with a rotary? The 3 ton XB13 has a LG scroll in it now.
Nordyne has a Samsung rotary in their cheapest 1.5 to 3 ton 13 SEER units. We've sold exactly 1.
Back to Trane, when they started buying Ameristar from Midea, they told them there must be scrolls in the units, no rotaries.
I am just going on what I was told by the boss man. He may have it wrong..... I will take a peak when the equipment shows up and report back.
If you are talking about small tonnage mini-splits... I think most of those are rotaries.
Copeland has a VRF scroll... it is based on the 36K BTU frame... runs 3000-7000 RPM based on a VFD box on the side of it...
Similar to an ECM motor if what I hear is correct.
As I understand, this is the pump in the GreenSpeed and Trane VRF units.
Greenspeed uses the Copeland but I am pretty sure Trane doesn't. They sound totally different, Greenspeed has high pitched whine while Trane does not. Trane VRF heat pump can vary between 25%-100% capacity whereas Carrier can only vary between 40%-100%. Also the compressor in the Trane does not look like a Copeland VRF compressor at all, it looks like a Danfoss
Trane VFR looks like this Danfoss scroll
1 - 8 of 83 Posts
