Which condensate pump to use?
9.1K views 7 replies 8 participants last post by  theoldscroll
#1 ·
Sometimes you have to use a condensate pump, which ones do you guys use? Which are the quietest in your opinions?
#8 ·
We have installed these for several years. I would recommend regular inspection of the rubber check device under the discharge fitting. These are not the standard little ball type and can plug with insects. I saw early models of these run till they melted the plastic over the motor. This problem seems to have been corrected.
#7 ·
I have installed little giant EC-OP series mini split condensate removal pumps 4 years back. And as per my experiences this is the best pump I ever used. It has Low weight, Compact size , high lift and quiet operation make the little Giant line of ABS pumps perfect for in-pan condensate and other wastewater removal .
