Also looking around for the same answer
Good day mate!
I too am looking at something a little bit faster but not damaging.
I work in a facility manufacturing aluminum wheels, and boy, did they not hire any HVAC minded guys for 8 solid years or even have anyone mitigate filters.
Currently my cleaning set up is a 5 gallon bucket with an air gun and an air hose used for siphoning out simple green. I would say the pressure is around 100 psi. I use 100 percent simple green with no water.
A quick look into the conditions these units operate under will explain why.
For 8 years, the fan blowing through the condenser, mind you that the fan intake is from the machine inside where you would not believe the mess of oil, coolant and fine aluminum dust combine, has pretty much conjured into a sweet dark caramel coating of about 3 to 4 mm thick. One would think, this unit is trash.
I do a lot of soaking. 15 minutes between blowings with the simple green. This is very effective, but with my work's demand to do other tasks beside A/C work, I want to make it faster. So now, I do a light scraping of the condenser with a spatula, then soaking and spraying and blowing. It's kind of like the Three Little Pigs story.
Simple green works pretty damn good for this oil and grime caramelized concoction. Fortunately, I have an area where I can dispose of the evidence.
To end it here, I guess my question is the same, can an 1800 psi electric pressure washer get me through the wall of caramel in a shorter time frame after soaking?
I highly appreciate all the responses on here from the veterans. I am self taught at the moment refurbishing small chiller units for spindles. Any extra experience shared, is worth a try.
Thank you.
