A newbie here.
I have a Modine Hot Dawg 30000 btu that I use to heat my workshop. The unit is the only gas appliance on the end of a long run of gas line. The line is a combination of 1" buried plastic and black iron pipe, the total length is about 100 feet.
The problem I have, is every fall when I start the unit after sitting over the summer it only lights one of the two burners and then automatically shuts down. I've had this problem for about six years now. First I thought maybe a little dust got in the burner or a spider web was causing the problem, but no matter what I do as far as cleaning, blowing it out with an air hose, jumping up and down and cussing, it won't light the second burner. About the time you have pulled out all your hair, it starts working and it never has a problem the rest of the heating season.
Recently I talked to another Hot Dawg owner that has the same problem each year. His solution is to purge the gas line each fall and his problem goes away.
So my question is, is it possible for natural gas to go stale in an unused line, or maybe separate out over a long time (maybe 5 months)? Someone said it's air in the line, which I can't believe cause it's under pressure all the time and the line has been pressure tested several times.
Ron
Ron
