I'm in a new build house and had an HVAC pro out to see if he could correct a problem where the airflow noise from two grills is very loud, but he wasn't sure what could be done. At least part of the problem is too much air flow to these areas.
There is a Lennox CHX35-51 air handler (not variable speed) on the attic portion of the third floor and the noise issue is in the spare bedroom and an adjacent bathroom basically just below the air handler on the second floor.
Our bedroom at the other end of the house does not have this problem. I can't measure the air flow but when the a/c is on the sound level in the problem room is about 65 db just below the grill and 45 db down around the bed, but it's a nice quiet 33 db in our bedroom.
Adjusting the vents or removing the grills does not quiet things.
The size of the box behind the grilles is 8" X 8" and the air supply is about 6 3/4" Diameter.
The tech that came (they did not do the original install) was not able to balance and lower the air volume for these rooms and tried lowering the fan speed on the air handler but said that was creating a pressure issue and the speed was better left as it was. Without opening up the ceiling on the second floor he did not see a way to make this better.
Have others here dealt with this before and have any ideas without opening things up? I had two thoughts and can someone advise if either is likely to help. Have the flexible duct from the air handler replaced with a lined for quiet flexible duct from the air handler to where it meets the floor to service the second floor (a distance of about 8' and the duct is about 10" OD), or have the inside of the boxes behind the grills lined with a sound absorbing material or have some kind of baffles installed.
