After installation and a year's operation of this poultry processing plant in Gardiner Maine, the inspectors have noticed and ordered that condensation issues be resolved. The main issue is overhead pipes that supply cold rinsing water to the process lines are condensing the high humidity in the environment and dripping onto the process lines.
The 24' x 36' x 12' high processing room has 3 large dehumidification units that are not sufficiently handling the humidity. A suggestion was made to add more units but the $40,000 price tag is not my first choice for my client.
I suggest insulation of the Pex pipes which are suspended overhead, or moving the entire piping system into the space above and creating penetrations into the process room from overhead.
Insulating would be simplest if there can be a guarantee that a foam wrap or sleeve applied to the Pex tubing would effectively bar the condensation on the pipe..... or if condensation still occurred within the pipe/insulation envelope, that there would be no general buildup and eventual leakage/dripping...i.e. does it solve it or does it just mask and postpone a problem? Are there insulating materials that would be ideal...closed cell foam formulations vs. janky hardware store stuff?
If this is not the best place to discuss this, would one of you experienced guys direct me to the best source?
thanks,
ccaissie
thanks,
ccaissie
