Hello Gents,
Haven’t posted in a while but I have a question about a turbocor compressor TT300. The compressor is on a Multistack.
The compressor was throwing up bearing alarms, calibrated the bearings and front bearing showed a flat line at the bottom with no Gain on the front axial.
I am going to pull the charge and ohm out the sensors and bearings, Can I get some help with procedure on this work? Specifically what pins go to what.
Also are there any rings or seals that need to be replaced on the pass thru connectors.
Thanks in advance.
Thanks in advance.
